Author Topic: DC07 lost all power?  (Read 8180 times)
Offline lucandhar
« on: September 25, 2011, 01:27:43 PM »
Cleaning with the DC07 today, done most of the house then suddenly had no suction at all, so took the filter out and it is spotless, unscrewed the cyclone lid & there was just a fine layer of dust so I emptied it, banged it all out and tried again still no power  :angryman:  :snivel:
So I stripped and washed it to this level
checked the wand, checked the hose, checked the blockage traps & cleaned the brushbar. NOTHING!
Does the post-motor filter affect suction? Mine's bad..
Offline lucandhar
Re: DC07 lost all power?
« Reply #1 on: September 25, 2011, 01:31:50 PM »
Here is what I cleaned
Offline lucandhar
« Reply #2 on: September 25, 2011, 01:32:22 PM »
Here is my post-motor filter
« Reply #3 on: September 25, 2011, 04:16:32 PM »
Are the two vertical channels each side of the chassis clear? Do you have suction at the wand?
Offline lucandhar
« Reply #4 on: September 25, 2011, 04:20:45 PM »
Yes, they are clear and not really suction is better at the base but the wand/hose isn't blocked   :sick0012:
« Reply #5 on: September 25, 2011, 05:03:19 PM »
Is the carriage mechanism working OK? That switches suction between the wand and base. The bit below the valve cover assembly that comes off with two buttons.
Offline lucandhar
« Reply #6 on: September 25, 2011, 06:05:47 PM »
Working fine  :underchair:
« Reply #7 on: September 25, 2011, 07:30:11 PM »
You sure the motor is OK?
That photo you posted shows the post motor area to be very, very black and carboned up.
That doesn't look too healthy from here.
Offline lucandhar
« Reply #8 on: October 01, 2011, 11:46:39 AM »
(Attachment Link)
It's black plastic, always has been. I wiped it with a damp cloth and the cloth turned grey, motor's been working as normal I think
Offline Angus Black
    • Dyson Medic
« Reply #9 on: October 13, 2011, 02:02:39 AM »
Remove the cyclone, there are two channels in the chassis. One is rectangular; one is D-shaped. Run the machine and put your hand over the one on the right. Is the suction strong there?
