Author Topic: Dyson V7 main motor current draw and pulsating issue  (Read 246 times)
Offline DaysonV7
« on: August 11, 2021, 10:03:54 AM »
Hello,
I got a Dyson V7 with a dead battery. I wanted to test the vacuum before I purchase a new battery. So I dismounted the back cover to get access to the motor. No attachments at the unit, only the handle+motor part. I use an external power supply to provide 26VDC to the input connectors. My power supply is limited to 3 Amps. I that even close enough on how much the motor needs? The motor is pulsating but never runs. I appreciate your help on this, as I gladly buy a new battery if I just know the motor is ok.
I can add a video later...
Offline DaysonV7
Re: Dyson V7 main motor current draw and pulsating issue
« Reply #1 on: August 24, 2021, 07:47:32 AM »
Here is the video. Any advice on what is wrong with the motor? PCB busted? No burned marks anywhere though.
