Author Topic: A little help!  (Read 1648 times)
Offline BobFrank232
A little help!
« on: September 30, 2021, 07:30:43 pm »
I got myself a DC19 for repair today. I noticed that a piece of the chassis has come loose(but not broken off) Is they anyway to fix it?
First time fixing Dysons so just wanted to know if it's fixable.
Thanks.
Offline dysondestijl
Re: A little help!
« Reply #1 on: September 30, 2021, 07:44:00 pm »
Hi. Often this is possible, depending on where the break is. Can you share a photo of the broken piece? That would help.
Many thanks
Offline BobFrank232
Re: A little help!
« Reply #2 on: September 30, 2021, 08:32:25 pm »
Here it is.
Offline BobFrank232
Re: A little help!
« Reply #3 on: September 30, 2021, 08:33:12 pm »
It came out of place then I put it back into place then checked to see if it went back but no.
Re: A little help!
« Reply #4 on: September 30, 2021, 09:18:19 pm »
That’s fairly common. That piece does come off. It will clip back on. Unless of course, the clips have snapped off. The machine will function perfectly fine without it if you aren’t precious about it- it’s really there to absorb bashes against furniture legs etc.
Offline BobFrank232
Re: A little help!
« Reply #5 on: October 01, 2021, 06:33:47 am »
So there's nothing to worry about?
Offline BobFrank232
Re: A little help!
« Reply #6 on: October 01, 2021, 08:09:50 am »
Is it possible to remove it and fit it back on?
Offline BobFrank232
Re: A little help!
« Reply #7 on: October 01, 2021, 09:37:10 am »
Or if not then buy a new one and see if it fits in place and doesn't move?
Re: A little help!
« Reply #8 on: October 12, 2021, 12:26:36 pm »
I don’t know if that piece was ever made as a spare part. I’ve never needed to order one. You might be able to find a used one from a machine someone has broken up though
