Author Topic: Dyson V7 Power and Motorhead problems got me stumped  (Read 173 times)
Offline kwells123
« on: November 03, 2021, 01:21:12 PM »
So I am currently attempting repairs on a V7 which has come in with problems of the motorhead not working.
voltage tested at the main body, bin and wand and is all fine.
So a new motorhead was purchased, when attached to either connection not only does the motorhead not work but also no power from the main unit, but there is a solid blue light on the battery, so the unit is responding to the trigger being pressed.
Without the motorhead attached the Dyson works fine.
This has now been tried and tested with 2 brand new motorheads and the same result from both.
This is not something I have ever come across so would appreciate any help. I have seen that a few other people have had similar problems, but there doesn't seem to be a solution on their thread.
At a guess I would be thinking that its a fault with the main board inside. But just wondered if anyone could help, before further tests etc...
Many thanks :)
Re: Dyson V7 Power and Motorhead problems got me stumped
« Reply #1 on: November 05, 2021, 05:17:34 PM »
Sounds like the main board inside as you say. We usually replace the motor body in that situation.
