Author Topic: Sucking Air at Dust Bin-Cyclone Junction--Faulty Gasket?  (Read 2746 times)
Offline lothian
« on: May 04, 2022, 02:38:33 pm »
I have no idea if this is the correct sub-forum to post my question. The Dyson upright has no model number; it just says "Dyson Slim Ball".
My vac is drawing air--and thus loosing suction overall--at the junction between the cyclone assembly and the dust bin. I suspect the gasket that seals the bin against the cyclone might be faulty; but it is pliant, has no tears, and fits into its groove snugly. I've taken to wrap the area with electrical tape. I'd like to replace this gasket but i cannot find the part number for it. Any idea what the OEM part number is for the gasket
Re: Sucking Air at Dust Bin-Cyclone Junction--Faulty Gasket?
« Reply #1 on: May 04, 2022, 03:16:54 pm »
They often leak a bit from gaskets like that when blocked elsewhere. It's a bit of a red herring.
From what you are saying, it may be a DC18, and the central hose under the head is the likely culprit.
The first three digits of the serial number would confirm the model.
Offline lothian
« Reply #2 on: May 04, 2022, 04:49:00 pm »
First three digits of the serial number: NP3
I'm not certain I follow you regarding central hose under the head. I presume by 'central hose' you mean the hose into which the wand passes; and I have no idea what the head might be. Is there a specific gasket or seal you suspect is the source of the leak?
« Reply #3 on: May 04, 2022, 05:58:55 pm »
That's not on our serial number checker. Is this a cordless or a mains machine? Is the filter on the top if cordless?
Offline lothian
« Reply #4 on: May 14, 2022, 04:32:55 pm »
« Reply #5 on: May 15, 2022, 11:26:22 pm »
That's a UP16, which I assume is an American model?
It's pretty much a DC40 anyway. Look here where the arrow is.
Look at this hose.
See if you can take it out and if its blocked.
Have you changed the filter?
Offline lothian
« Reply #6 on: May 16, 2022, 12:23:56 am »
I checked that short length of hose. It's clear.
The problem seems to be at the junction between the cyclone assembly and the dust bin. After I wrap the junction with electrical tape, full suction is restored. Any idea what the OEM part number is for the gasket for a up16/DC40?
« Reply #7 on: May 25, 2022, 04:24:10 pm »
You can find a schematic for your model >here<.
Offline lothian
« Reply #8 on: May 25, 2022, 04:29:00 pm »
Thanks for the link.
It appears that the suspect gasket is not sold as an item. Bummer.
Offline lothian
« Reply #9 on: September 19, 2023, 01:58:31 pm »
A long overdue follow-up:
You were absolutely correct! The short hose you suspected as the likely culprit of the air leaks around the gasket was completely impacted! Dunno how I missed it before.
You clearly know your Dyson vacs!
« Reply #10 on: September 21, 2023, 05:34:51 pm »
Thanks for the follow-up, not everyone takes the time. It's a great help to other passers-by.
