Author Topic: DC25 No Power to the Cleaner Head: MV Yoke Loom Fitting Instructions  (Read 7528 times)
If you have a DC25 and the brush roll isn't turning but you know the head is in good working order, you need to check that you have power coming out of the machine to the cleaner head. If you haven't, the yoke loom is the likely culprit.
Dyson used to supply it on the plastic frame, part number 916190-01, but has now discontinued the part. So we now make them instead, you'll reuse your existing plastic frame. There's a good explanation on Dyson Medic >>here<<.
You can buy one from us on our site >here<, on eBay >here< or on Amazon >here<.
Here is the video we made that shows you how to fit it.
Offline Brody2009
Re: DC25 No Power to the Cleaner Head: MV Yoke Loom Fitting Instructions
« Reply #1 on: September 12, 2022, 02:09:39 pm »
I have a Dyson dc 25, when you recline the machine so the head is off the floor, the head spins normally. As soon as you place the machine in the hoover position, the head stops spinning. I have replaced the reset switch and brush bar switch as well, but the fault still persists.
« Reply #2 on: September 12, 2022, 06:48:29 pm »
That's a classic symptom of this loom being broken.
Offline Brody2009
« Reply #3 on: September 13, 2022, 09:39:58 am »
Than you so, so much. Have ordered a loom from you.
Offline Brody2009
« Reply #4 on: September 17, 2022, 01:22:42 pm »
I have removed the old loom,there do not appear to be any breakages.  I repacked it in any case.  The same fault still persists.  Could it be that when the fault first showed itself something had been hovered up which jammed the head that the end of the head has been stripped and needs replaced?
Offline Brody2009
« Reply #5 on: September 20, 2022, 07:14:21 pm »
I have fitted a new loom, the same fault as before remains.
"I have a Dyson dc 25, when you recline the machine so the head is off the floor, the head spins normally. As soon as you place the machine in the hoover position, the head stops spinning. I have replaced the reset switch and brush bar switch as well, but the fault still persists."
 Could it be that when the fault first showed itself something had been hoovered up which jammed the head that the end of the head has been stripped and needs replaced?
« Reply #6 on: September 20, 2022, 08:43:46 pm »
Having replaced the loom (it would go at some stage anyway), and assuming you have circa 320v DC to the motor, I'd be inclined to swap the brushroll motor next as the PCB is unlikely. If you want to do it inexpensively, we have some good used tested ones for which I'll send you a DM with a link.
Offline Brody2009
« Reply #7 on: September 21, 2022, 09:32:48 am »
That would be great, many thanks. Are there instructions how to do this. Video on how to change the loom was great!
« Reply #8 on: September 21, 2022, 01:50:57 pm »
Ta, the DC25 brushroll one isnt as slick, but its here:
Offline Brody2009
« Reply #9 on: September 24, 2022, 07:31:46 pm »
Received the motor and again followed the excellent video. Same fault still persists  :snivel:
« Reply #10 on: September 25, 2022, 09:10:12 pm »
I'll ask our tech chap on this tomorrow.
Offline matrixresonator
« Reply #11 on: September 26, 2022, 07:59:58 am »
Only other thing I can think of is the PCB isnt putting full voltage out, or maybe the switch near the loom that avtivates power to the head.
Offline Brody2009
« Reply #12 on: September 27, 2022, 05:22:30 pm »
Regarding the switch near the loom, how much does it cost and again any videos on how to fit it please?
Offline Brody2009
« Reply #13 on: October 04, 2022, 05:32:06 pm »
Still have the same problem.  Mention was made about the switch near the loom, can these be purchased?
Offline __russ__
« Reply #14 on: October 04, 2022, 11:42:00 pm »
Have you looked at the black drive cog in the cleanerhead that spins the brushbar?
That, or the clear part inside the brushbar, might have rounded off so it doesn't spin the brushbar under load.
