Author Topic: Dyson DC46 Allergy Parquet - Stripdown and Refurb!  (Read 3683 times)
« on: October 02, 2022, 07:21:56 pm »
I bought this from Facebook, near Reading for £20 iirc!
This was never sold in the UK. The guy said they bought it with them when they moved from Switzerland. And yep, Dyson UK have no record f it
It's very nice
Forrin plug
and ALL the tools!
Which weren't too bad tbh
Re: Dyson DC46 Allergy Parquet - Stripdown and Refurb!
« Reply #1 on: October 02, 2022, 07:25:47 pm »
Felt strips gone as they always are
They did an electric hose variant of this shape somewhere in the world, and this is evident by the shape of the hose inlet. Just right for some pins and a socket right there
Little blockage clearing port
I put the hose and filter in the wash, and got on with knocking everything apart
Tools first
Small tools split
The hard floor tool now
It's a horrible tool tbh, and much better if, once you remove the brush strips you throw the middle long one in the bin and don't refit it. Works alot better then!
Flat out head next
« Reply #2 on: October 02, 2022, 07:29:25 pm »
I've never known how to take these apart and never managed it, so I picked all the fluff out and washed it whole
'Turbo' head now
There's a screw at the back
And the parking bracket comes off
The front hose cover trim part comes off now, and again note the places for wires to run on the electric version of this head
The wheels would not come off. I guess their press fit with sharp big barbs so I left them alone
I did pull this out from underneath though
and moved on
Brushroll out
« Reply #3 on: October 02, 2022, 07:33:44 pm »
I tried to remove the black brushes carefully but snapped one of the white holders
Front baseplate off
Front wheels removed
The rear baseplate is held in with a clip underneath at the rear
And once unscrewed pops off
The clear window comes out next
The turbine cover can be unscrewed now
And the whole assembly lifts out
The turbine assembly splits at the middle
« Reply #4 on: October 02, 2022, 07:38:00 pm »
At the brushroll end, the belt pops off the top cog, and the whole thing hinges off
And with the removal of a pin can be separated
But not much else can be now. The main turbine casing splits
And the air inlet filter pops off
Time to move onto the machine itself, which is quite familiar tbh
Blockage pipe off
Underneath these 4 screws come out
Revealing thus U-shape spring arrangement
The springs come out when it's removed
« Reply #5 on: October 02, 2022, 07:45:15 pm »
Next up we remove the ball shells
Post motor filter out, full of hair
The screws holding the main housing together come apart now, and with it the hose inlet
The top shell lifts off, although the flex is still going through it
The cable exit bit pops out of the top housing
2012 for this cord reel
The hose inlet has this trim part on it
Underneath the top housing is a big black piece
And some scary looking springs
« Reply #6 on: October 02, 2022, 07:49:21 pm »
With the cable rewind brake going behind it too
Out it all comes
Power and cord reel buttons pop out
Then the top handle/suction duct can be removed from the top housing
Onto the lower housing now, and there's a white bush inside the hose pivot mechanism you don't want to lose
Then I secured the cord reel so it didn't lose all its tension
And lifted it out
The exhaust air diffuser and t's holder come out, as well as the parking bracket
This firewall piece slides out
« Reply #7 on: October 02, 2022, 07:52:59 pm »
We can move onto the motor now
The switch unscrews and comes off with its carrier
On the cord reel, it turns out the 3 tension springs come out on their own little assembly nice and safely
Which then allows the cord reel to be removed from the motor housing
The ball shell axle can be unscrewed
The wiring unpicked
And then the motor can be removed
The motor has a rear housing on it still though
« Reply #8 on: October 02, 2022, 07:56:29 pm »
Which unscrews and has the wires detached
And eventually we get down to the bare little motor
And can move onto the cyclone
Bin off
Lower flap and rubbers off
Work around the top edge of the shroud and unclip it from the cyclone assembly
Somewhere under here are some screws...
And a thin fragile rubber gasket
« Reply #9 on: October 02, 2022, 08:00:33 pm »
Which is broken...
Work around the edge and remove all the small screws, and layer 1 comes out
Bin flap release button and its spring come out
Top cover and the broken foam gasket come off
Moving on up the layers, after some digging I found the next round of screws
And the top cover comes off the 2nd layer of cyclones
The top gasket didn't seem as terrible though. Cyclone carry handle removed too
Everything was stripped down and ready for washing
Very busy screwcard
« Reply #10 on: October 02, 2022, 08:04:43 pm »
Whilst all this was going on, I'd had in, and scrapped because they were broken, 2 Dyson DC49's, the digital motor version of this exact machine! I kept one of the flex's
Fitted it very easily
And made the machine a bit easier to use. The 2 pin dyson plug was fragile as anything, bent a pin just storing the machine...
Everything was washed, dried and polished, and ready to go back together!
There are ALOT of screws!
First up, replace the rubber seals to the lower bin flap
Then fit the flap to the bin
The top layer of gasket and cyclone tops was assembled
« Reply #11 on: October 02, 2022, 08:08:20 pm »
Little handle refitted
Then the inner cone/filter housing can be dropped in
The 2nd layer of gasket and cyclone top was looking quite bad however, and I could not find any gaskets for these cyclones easily at the time...
So some clear silicone later and I got it air tight
Pop the bin open button and spring back in
Then bring the 2 parts together
Once screwed up, the tiny edge gasket was complete if broken, and did go back on very nicely
The outer cover can go on now
Then the shroud
« Reply #12 on: October 02, 2022, 08:11:52 pm »
Then drop the pre motor filter in
Moving on, build the motor outer cover back up
And fit it all back into its housing
Fit the motor cover/cord reel contacts
Screw on the switch and tuck all the wires in
Drop the firewall part into the lower housing
Fit the cord reel, springs and retainer
Up top, clip the top handle/suction duct in, and fit the springs to the pivots
Then fit the switches, springs and black retaining plate to hold everything together
« Reply #13 on: October 02, 2022, 08:14:52 pm »
Place the motor unit into the lower housing, and refit the hose connector
Fit the main housing back together
The post motor filter got a good airline out and came up alright
Clipped back in
And the ball shells can be refitted
Underneath, fit the hose pivot spring
And cover it up with the plate
Blockage plate refitted
Getting there!
« Reply #14 on: October 02, 2022, 08:17:29 pm »
Turbo head now. Clip the filter onto the turbine housing
Then clip the 2 turbine parts together being sure to seat the rubber gasket correctly
I put some new grease on everything
And re-assembled the spinny bits
And fitted them to the chassis
Clear and not clear covers fitted
Baseplates on
Brushroll assembled
And fitted
