Author Topic: DC07 Hard to push  (Read 9103 times)
Offline aceone
DC07 Hard to push
« on: November 19, 2011, 04:47:10 PM »
Hi  i have a dc07,the problem is when i use it ,..the soleplate is sucked to the floor so much it is hard work to push and pull,if i vacuum lino it lifts it up.....puzelled, as it used to be fine,i have taken ik apart but cant see what might be the problem,...any ideas please
Re: DC07 Hard to push
« Reply #1 on: November 20, 2011, 09:49:49 AM »
Is it clutched or non-clutched?
Offline aceone
« Reply #2 on: November 20, 2011, 10:59:54 AM »
Hi,...its the non-clutch model i have....thanks
« Reply #3 on: November 20, 2011, 02:05:46 PM »
Look at the angle the tilting cleaner head is contacting the floor, it may be a little tilted. Turning the bottom hose a bit usually cures that. Failing which, take off the sole plate, and remove the rubber seal.
I bet there is nobody on a forum anywhere saying their Hoover or Vax sucks so well it sticks to the floor and cannot be pushed.  ;D
Offline aceone
« Reply #4 on: November 20, 2011, 04:19:58 PM »
thanks for that info,....yes you would think i would be glad havving a vac with so much suction...some people are never happy...lol
« Reply #5 on: November 21, 2011, 12:19:48 AM »
To be honest, its a pretty popular thing we encounter with machines we recondition. Usually non-clutched ones.
We haven't managed to nail it down to any one thing, but as daft as it sounds, we just have to tweak it to reduce the suction. Removing the sole plate seal is the usual way. It just allows that bit more air to pass by and reduces the suction just a little. Other than that, we fit a more worn brush roll; again just to try and reduce the efficiency of the machine.
Offline aceone
« Reply #6 on: November 21, 2011, 09:16:01 PM »
Hi   thanks for that info,i will follow your sugestions and see what happens.....thanks again
« Reply #7 on: November 22, 2011, 12:15:18 AM »
Come back and tell if it is cured or not.  ;)
Offline aceone
« Reply #8 on: November 22, 2011, 07:11:41 PM »
Yes i will    thanks
Offline aceone
« Reply #9 on: November 26, 2011, 08:36:16 PM »
Hi again,had a play about with the Dyson,... seal on soleplate had already been removed so turned the bottom hose bit by bit but little or no improvment,I think ill just use this one for spares now,may i just say thanks for all your advice.......... :tiphat:
