Author Topic: V11 pulses even after complete strip-down and clean  (Read 846 times)
Offline Alex1955
« on: December 21, 2022, 06:36:31 AM »
I have a V11 which has started pulsing on the med and eco settings, which I understand is normally a sign of restricted airflow/blockage. (No pulsing on the boost setting).
I stripped it down completely, cleaned everything, re-assembled, fitted a new filter, and still it pulses. I am absolutely certain there is no blockage.
The cyclone motor even pulses when its completely stripped down (ie only the electric motor, plus filter, plus battery). I suspect a faulty sensor......
Any ideas anyone?
Offline matrixresonator
Re: V11 pulses even after complete strip-down and clean
« Reply #1 on: December 21, 2022, 07:34:33 AM »
Had this last week, I was of the same thought as you regarding the sensor.  Replaced the main body unit and it's running fine now.
Offline Alex1955
« Reply #2 on: December 21, 2022, 10:00:12 AM »
Hi - when you say "the main body unit" - you mean the electric motor?
« Reply #3 on: December 21, 2022, 10:04:52 AM »
Yes the main body with pcb and motor.
970142-01
