Author Topic: DC 14 just won't turn on  (Read 9759 times)
Offline mtestes
« on: November 26, 2011, 04:32:09 PM »
I am in the US and I have a DC14 that just turned off while I was using it.  I read online to clean brush and check for clogs then to press a reset button on the side of the vacuum or under the hood.  I can't find any reset switch.  Can someone please show me where this is?  I hope this solves my problem.
Also IF that works, I also have another issue with a piece that cracked off where the hose attaches to the upright shaft.  The hose will not stay in place without this piece.  I have glued it several times but because of taking the hose on and off it continues to come off.  It looks like there isn't a way to replace that as it is the main piece of the vacuum.  THANKS!
Offline mtestes
Re: DC 14 just won't turn on
« Reply #1 on: November 26, 2011, 06:56:46 PM »
Ok my husband figured out it was the power cord.  He fixed it but if someone knows the answer to the 2nd half of this question I would appreciate it!
Offline Angus Black
    • Dyson Medic
« Reply #2 on: November 27, 2011, 02:23:50 AM »
Is this piece at the top or bottom of the hose? Is it on the hose itself?
Offline mtestes
« Reply #3 on: November 27, 2011, 02:30:34 AM »
It's not on the hose.  Its the part the hose clicks onto the vacuum.  It's directly behind and between the red on/off button and the red button that releases the canister.  Does that help?  I can take a picture.
Offline mtestes
« Reply #4 on: November 27, 2011, 03:06:50 AM »
« Reply #5 on: November 27, 2011, 08:41:42 PM »
You need a chassis to fix that I'm afraid.
Changing it also involves a full strip down.
As you are in the US, a new one can be had from Sears but they are an eye-watering $154. See here: http://tinyurl.com/c59rs7o
The part number for the US is 908656-03. There will be other suppliers if you Google.
The UK part numbers are: 908656-01, 908656-02 and 908656-05
I don't see why a UK one wouldn't fit, they are not expensive here new (About $56) but shipping wouldn't be cheap as its a big box and couriers charge by volumetric weight rather than actual weight. Sniffing out a used one on eBay in the US would be my first choice.
If you are reading this in the US and you have one of these, do holler.
Offline mtestes
« Reply #6 on: November 27, 2011, 08:51:38 PM »
Thanks so much!! I will have to keep an eye out on Ebay now that you have helped me identify the part! THANK YOU SO MUCH!!!
I can vacuum with it but it proves harder then before! LOL
