Author Topic: Brush Bar motor not spinning - only getting about 250V DC  (Read 1038 times)
Offline 00bins
Hi
I've read through a lot of posts about this part and so far not found anything definitive.
I seem to be only getting 250V instead of the 300V I've seen quoted
Would that be the reason the motor doesn't spin? Or is it possibly both the PCB _and_ the motor?
cheers
Rob
Offline 00bins
Re: Brush Bar motor not spinning - only getting about 250V DC
« Reply #1 on: May 05, 2023, 03:46:20 pm »
Also, reading 0 Ohms across the motor terminals makes me suspect the motor is dead.
« Reply #2 on: May 07, 2023, 11:16:28 am »
I would still expect the motor to spin if you are getting around 250V DC at the terminals. It's not uncommon for a motor to blow and short out the PCB with it. Sometimes there is visible scorching on the PCB as a result, sometimes not.
Offline 00bins
« Reply #3 on: May 10, 2023, 11:34:18 am »
Thanks - I've ordered a second hand replacement (the whole unit)
