Author Topic: DC25 motor dose not run when handle upright  (Read 1231 times)
Offline Les798
« on: June 26, 2023, 05:06:07 pm »
Hi my DC25 motor does not run when handle in upright position so can’t use wand any ideas
Regards Les
Re: DC25 motor dose not run when handle upright
« Reply #1 on: June 27, 2023, 11:39:39 am »
Main motor or cleaner head motor?
Offline Les798
« Reply #2 on: June 28, 2023, 04:27:07 pm »
Hi MVacs
Thanks for reply
It’s the main motor which does not run. When you lower handle it works as it should but lock it back on its wheels to use the wand nothing
Regards Les
Offline matrixresonator
« Reply #3 on: June 29, 2023, 08:23:03 am »
There as 2 motors on this machine, with a 2nd for the brush roll which should cut out when in the upright position.
It sounds more likely the main motor has failed and isn't running at all, and the brush motor is kicking and out as designed.
Offline Les798
« Reply #4 on: June 29, 2023, 08:48:40 am »
Hi thanks for reply I will check that out but pretty sure main motor runs a it hoovers up as normal
Regards Les
