Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
With photos. Find it
>here<
Click
>here<
Home
Help
Login
Register
Dyson Models
Dyson DC04
beater bar?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: beater bar? (Read 5083 times)
mikeyh
Member
beater bar?
on:
December 11, 2011, 08:45:34 AM »
Tweet
our DC04 has been stored for a couple of years. now needed, the beater bar turns a couple of times and then stops. the motor spindle continues turning and causes the fanbelt to burn and break.
Can i repair or is a new bar needed?
mike
Logged
Angus Black
Member
Country:
Gender:
Re: beater bar?
Reply #1 on:
December 12, 2011, 12:03:16 AM »
It sounds like you have a seized brush roll.
You can replace the bearings but it is often a false economy.
As you didn't mention a clutch, I am assuming you have a grey/green DC04? If so, I recommend changing the brush roll and the belt.
Logged
The Dyson Medic Blog
The original Dyson Medic
aceone
Member
Re: beater bar?
Reply #2 on:
December 12, 2011, 06:24:59 PM »
Try removing the beater-bar,pull off the end caps,remove any fluf etc either end of the bar and spray with a little wd40 ,,and as said in previous post replace the rubber belt that should sort it out,
Logged
Print
Pages: [
1
Go Up
« previous
next »
Dyson Models
Dyson DC04
beater bar?
