Author Topic: DC05 Motor head  (Read 6485 times)
Offline dc05
DC05 Motor head
« on: January 09, 2012, 12:10:58 pm »
Ok I have Dyson dc05 motor head. The motor burnt out and was panasonic. I bought a new ydk motor, new bucket and rubber mounts. The wiring is a little different and need a hand to be told or shown what i need to do to wire up correctly. I understand that the motor heads need extra mod but unsure just what exactly needs to be done in regards to this extra neutral point on motor.I have had a try to wire it the way i thought it would go but vacume would not work. Any help would be appreciated. Kind regards in advance.
Re: DC05 Motor head
« Reply #1 on: January 09, 2012, 12:38:23 pm »
How many wires do you currently have coming out of your motor housing?
Also, have a read of this post and see if that helps any: https://manchestervacs.co.uk/DysonForum/index.php/topic,334.msg1359.html#msg1359
Offline dc05
Re: DC05 Motor head
« Reply #2 on: January 09, 2012, 12:55:49 pm »
yes i did read that post but it isnt specific on what actualy is involved with this extra conection point
Offline dc05
Re: DC05 Motor head
« Reply #3 on: January 09, 2012, 01:13:03 pm »
This was how i thought it would wire up?  Obviously not assembled in pic.
Offline dc05
Re: DC05 Motor head
« Reply #4 on: January 09, 2012, 01:37:49 pm »
think i found problem .... a loose connector in front clear housing it wasn't all the way pushed in once it was it fired up. I'm happy and hope these piece can help someone else
Offline MV Claire
    • Dyson & Sebo Specialists
Re: DC05 Motor head
« Reply #5 on: January 09, 2012, 03:06:08 pm »
Thanks for the photos too. We get a lot of Aussies with these machines asking about them.  :thumbsup:
