Author Topic: DC18 purpose of microswitch  (Read 6017 times)
Offline guitarsjm
« on: May 11, 2012, 10:27:39 pm »
whilst taking apart this lovely piece of plastic... i noticed  a red wire pair... come to find out, its for a micro switch.  can someone enlighten me as to what function this serves and to what purpose.
thank you... i did try and locate an answer but found none
Offline Angus Black
    • Dyson Medic
Re: DC18 purpose of microswitch
« Reply #1 on: May 13, 2012, 11:43:53 pm »
It switches on he brush roll when the machine is reclined.
Offline guitarsjm
« Reply #2 on: May 14, 2012, 02:40:03 am »
thank you.. (then what is the purpose of having a brush switch on the handle if there is already an automatic one down below?)
Offline Angus Black
    • Dyson Medic
« Reply #3 on: May 14, 2012, 07:33:42 pm »
That is a question for Dyson's designers.  :))
Think of it like a double switched circuit. Rather like a rear fog light on a car; there is a switch but it wont bring the lights on unless the dipped headlamps are on too.
Offline cleanman27
« Reply #4 on: May 16, 2012, 10:43:40 am »
When the cleaner is in the upright poistion the microswitch turns OFF the brush motor. If this didn't happen the brush would continue to rotate in one place on the carpet and could cause wear, it would be a bit of a bind to have to remember to do it each time.
The switch on the handle, near the main switch, allows you to turn off the brush motor when you don't want it to run, i.e. on a shag pile carpet or other delicate items.
On my DC24 at odd time the head brush will not start immediately after using the suction tools or will run for a few minutes then stop. The Dyson tech changed the handle switch but it hasn't made any difference.
Clean by name clean by nature.
