Author Topic: DC24 stabilizer wheel spring.  (Read 8317 times)
Offline cleanman27
« on: May 15, 2012, 03:31:46 pm »
Hi all,
have changed out the motor on my DC24 and it works well. However I am having trouble with the rear stabiliser bar spring. The spring wasn't taken off the stabiliser bar but the bar was released from the housing. I am unable to work out how the spring should be refitted and it looks distorted when the machine is in the upright position. Do not recall that looking like that before. Stupidly I didn't take note of the position when I dismantled the machine.
Clean by name clean by nature.
Offline cleanman27
Re: DC24 stabilizer wheel spring.
« Reply #1 on: May 16, 2012, 09:15:49 am »
Ok if you don't have a fix could one of you DC24 owners take a photo and post it on here of your stabilizer spring. This is the spring that makes the pair of wheels at the lower back spring up when the red bar is pressed.
many thanks
« Reply #2 on: May 17, 2012, 10:47:34 pm »
See if the attached photo helps you. One I had in bits today........
You can click the picture to make it bigger.  ;)
Offline cleanman27
« Reply #3 on: May 20, 2012, 05:26:57 pm »
Many thanks all OK now. Easy fix just pushe dthe spring through from the position it was in to trhe inside of the location. Found out that my neighbour has same machine and looksee with the MK1 eyeball confirme dthast my unit spring is now in the correct position.
Thanks again.
