Author Topic: DC14 burning smell & now wont start  (Read 8043 times)
Offline cfrost31
« on: May 21, 2012, 09:53:14 am »
We have had the DC14 Animal for a few years now - no problems until today!  We got a burning smell and a couple of pops from the motor.  Turned it off & then back on - nothing.
I started to disassemble it - sponge & HEPA filters were solid - sponge now washed out.
Fuse & switch OK - suspect the motor (and after reading other posts here - very strongly suspect the motor) - So ... How do I get at it & how can I make sure (before ordering a replacement part)? I have removed all the torx screws - but cannot see how to remove the motor cover.
Offline cfrost31
Re: DC14 burning smell & now wont start
« Reply #1 on: May 21, 2012, 08:20:03 pm »
OK - so I followed the DC07 disassembly guide on the 'Dyson medic' site - which was close enough.  I now have a motor - which does not seem jammed, does not smell of burnt wiring and even seems to have reasonable length brushes.
But INFINITE RESISTANCE across the  two leads - so does that confirm a dead motor?
« Reply #2 on: May 21, 2012, 11:15:22 pm »
Infinite resistance is a burn out (An 'infinite' resistance reading across a motor indicates an open winding). Badly clogged filters means a burn out. Burning smell and popping means a burn out.
Yes, you need a new motor.
