Author Topic: DC04 Brush Control motor?  (Read 5272 times)
Offline steersk
« on: June 12, 2012, 08:08:41 PM »
Hi
I have a Dyson DC04 brush control model and I would like to replace the motor. I see on eBay that the DC07 motors fit the DC04. Is this true?
We are moving to the states and I don't want to replace the old thing - Its 12 years old and it would be a shame to chuck it now! :(
If I could replace the motor with a US model for the DC07, and change the power cord, would I be set to go? :reading:
Thanks in advance!
Re: DC04 Brush Control motor?
« Reply #1 on: June 13, 2012, 07:44:12 PM »
Thanks in advance!
If the US motor is a YDK one from a DC07, that should be fine.
If a Panasonic one or another brand, you may have difficulties with motor rubbers etc.
Offline steersk
« Reply #2 on: June 14, 2012, 04:46:08 PM »
it is the YDK one I will be using.
This one OK?
http://www.vacuum-direct.com/dyson-dc07-service-kit.aspx
If not, can you suggest a retailer?
Dyson will not sell you a motor or power cord because they say you need it fitted by a qualified Dyson Engineer.  ::)
Offline Angus Black
    • Dyson Medic
« Reply #3 on: June 14, 2012, 10:54:03 PM »
This one OK?
That will likely work. Use your own motor rubbers with that conversion though.
DC04 Spare Parts
