Author Topic: Dyson DC17 (USA) How does the upright microswitch sit inside LMC Motor housing?  (Read 9134 times)
Offline mancalvo1
Dyson DC17 (USA)
1. How does the upright micro-switch sit inside LMC Motor housing? I want to replace the switch, but I need a picture to show the position and location inside the motor housing.. Cheap help took it apart and now I need to put it back together >:( the exploded diagram does not show the exact location and orientation.
Thanks!
Manolo
Offline mancalvo1
I figure it out.. I don't need any help for right now.. The upright micro switch gets inserted into a cavity of the lower motor housing cover and onto the side of the plastic actuator. the wires are tucked into the routing slots, which hold the wires in place.
Offline mancalvo1
Correction: upper housing cavity since you will be working with the pre-filter cover sitting on top of the table and the hose/arm hanging down towards the floor. The pre-filter cover is flat and therefore is stable when working on this area.
