Author Topic: DC20 On/Off Switch Problems  (Read 6019 times)
Offline purplegrum
« on: June 27, 2012, 08:02:45 pm »
Hi Everybody,
I was wondering if anyone could give me some advice on a problem I'm having with my DC20.
It's a great little machine and has gone through hell and high water with me however it now won't stay on unless I hold the on/off switch down with a bit of tape.
I'm not sure if I should be looking to replace the switch itself, the actuator or both - don't even know how to get the thing apart!
Any advice would be really appreciated!
Cheers
Offline Mike Aberdeen
Re: DC20 On/Off Switch Problems
« Reply #1 on: June 27, 2012, 11:18:24 pm »
If you need to hold it down with tape, it will be the switch itself. The switches are the same on most models, so you should be able to buy a DC04/7/14 one and it will be fine.
Offline MissPractical
« Reply #2 on: October 15, 2013, 06:09:38 pm »
I've also got exactly the same problem with my DC20, and like the original poster can't work out how to get into it to get under the on/off switch and see if I can fix it.  I've managed to remove 2 star screws (using a flathead screwdriver) from under the washable filter, however this does not seem to release the top half of the machine which has a join around and looks/feels like it should be removable.  Does anyone know how to get into this DC20 animal?!!
« Reply #3 on: October 17, 2013, 12:50:43 pm »
For anyone with the same problem, I've worked out how to get into the DC20!!  Thanks to this vid - see attached.  It's for a DC08, but the machine is very similar and it's exactly the same principal.
« Reply #4 on: October 17, 2013, 03:02:55 pm »
The chap who made that vid is a member here. He knows his stuff.  :thumbsup:
