Author Topic: DC15 Brushbar not operating  (Read 10819 times)
Offline paclx
« on: January 02, 2013, 05:01:18 am »
I have a DC15 and the brush bar motor isn't working. The fuse (F1) on the PCB has blown. I have disconnected the brushbar motor, the white (switch) wires and the yellow/orange (motor) wires on the PCB and replaced the fuse. but it still blows when the power swith is turned on. The main motor is operating. Is this a faulty PCB?
Offline premierdysonrepairs
Re: DC15 Brushbar not operating
« Reply #1 on: January 02, 2013, 09:43:57 am »
Would think that there is a fault in the on/off switch or a short in the motor, the p.c.b alone would not take the fuse out.
Offline paclx
« Reply #2 on: January 02, 2013, 10:01:22 am »
Thanks for the reply. I have tested with the motor leads disconnested from the PCD to eliminate/isolate the possibility of a motor fault, but the fuse still blows. The switch by the handle for the seems to be momentary and not latching. Is this correct? I have actually dimantled both the power on/off and brushbar switches, and they don't appear to have the same mechanism inside.
« Reply #3 on: January 02, 2013, 10:11:03 am »
Not sure if i followed you correctly, are you saying the fuse blows with the motor disconnected?
The switches are prone to falling apart inside causing a short also if any of the circuit wiring is rubing it could cause a short.
Offline paclx
« Reply #4 on: January 02, 2013, 10:47:03 am »
Correct. Brushbar motor and switch wires at the bottom of the PCB are disconnected. I've tried a new fuse, and it blows when I switch on the power. Main motor keeps working fine though. The only wires still connected are coming from the switches on the handle, red, brown and blue.
I have just tried disconnecting the brushbar switch (brown and red wires), fuse still blows. Now running out of fuses :(
« Reply #5 on: January 02, 2013, 12:13:27 pm »
Last time we had one of those blowing fuses a new PCB fixed it.
