Author Topic: DC07 clutch problems, maybe?  (Read 4260 times)
Offline StringWells
« on: March 12, 2013, 02:30:37 PM »
I acquired this clutched, hepa model which had a severe screeching noise from down below. I stripped it down and found the brush bar was seized. I stripped and checked the clutch which seemed ok. I fitted a new brush bar and it worked ok for a few months until the brushes burnt out. I replaced the motor and now the screeching noise reoccurs when the clutch is engaged. It may go ok for a few moments ok, but then suddenly starts screeching. What sort of faults can a clutch develop?
Online __russ__
Re: DC07 clutch problems, maybe?
« Reply #1 on: March 12, 2013, 02:39:28 PM »
Try the easy fix first - pop the end caps off the brushbar, clear out any dirt, hair etc out of the ends and give the bearings a good lubricate and see if that makes a difference .
I would say that's the most likely culprit of the screeching
Offline StringWells
« Reply #2 on: March 13, 2013, 06:40:25 PM »
Right: I have dismantled it a bit. I took brush tray and clutch assembly out and lots of bits of rubber present. I'm thinking I may have replaced clutch assembly and twisted the belt last time!  :snivel: Now I'll wait for some dirt to appear and test it properly. Anyway thanks for your prompt help  :tiphat:
