Author Topic: DC18 Main Motor does not remain on after releasing the red push button  (Read 6924 times)
Offline Fboar
Today, our DC18 began not staying on after releasing the red push button.
We were using the wand and the main motor would only stay on with the button depressed.
I removed the 4 screws holding the switch cover. Nothing appeared to be broken. After putting it back together, it would still only run with the button depressed.  This is true with the wand in use, or with it in the handle.
Can anyone tell me what the problem is?
You want a new power switch: https://manchestervacs.co.uk/Dyson/DC15-spare-parts.html
12th item down on the page. Ignore it says DC15 - they are the same.
Offline Fboar
Thanks!
Thanks!
I see now by your flag you are in the States, the page I linked you only does UK.
You want 12th item down on this page: https://manchestervacs.co.uk/Dyson/DysonSparePartsUSA.html
Offline Fboar
I suspected that this might be the case.
I found the part on several US websites by Googling the part.
Thank you for the help!
Offline Fboar
Thanks again for your help. I received the new switch. Now I have the problem of removing the switch cover to access the power switch.
I removed the 4 Torx screws with no problem. This frees up the upper part of the cover, however something is holding the bottom section of the switch cover. The cover moves so whatever is holding it is not a screw. The upper portion of the switch cover will rotate outward about 20 degrees, but that is as far as it moves. There is nothing on the back side which can be popped to release the cover.
  • I tried using a powerful LED light to look behind the cover, but it is not possible to see anything.
  • I slide a very thin screw driver between the switch cover and the body, but could find no tabs which would realease the cover.
  • I checked on the internet, but every photo of the switch cover is from the front which provides no clues as to what is holding it in place.
  • There is a Youtube video describing the removal of a DC07 switch cover - remove one Torx screw and it pops right off. This is nothing like the DC18 Slim that I have.
  • Several other people are asking the same question, and the only suggestion is "more elbow grease." Any more elbow grease and I will only succeed in breaking the switch cover.
I would appreciate any suggestions for removing the switch cover without breaking it.
Thank you.
Offline Fboar
From a post on the DC25 forum:
Quote
Replace the two bottom screws but don't tighten up just a few turns in will do, then using the screwdriver push firmly each screw and this will release the lower part of the cover hope this helps.
This worked!
