Author Topic: dc05 motor  (Read 6229 times)
Offline markcarl
dc05 motor
« on: July 06, 2013, 05:44:53 pm »
hi guys, i have stripped down my dc05 and find that i have the panasonic version motor, there was 2 wires going to this motor but now i want to put things back together i need to know which wire goes to which terminals as i forgot, i normally take pics , now i wish i had so if any one can help, brill
cheers david
Re: dc05 motor
« Reply #1 on: July 06, 2013, 07:14:40 pm »
You have this motor?
Are the two circled spades not different sizes? I haven't got one in front of me so I cant check to be certain.
By the way, in case of need (or maybe for others) there is a DC05 motor swap guide here: http://dysonmedic.com/DC05%20Folder/DC05%20motor%20change.html
Re: dc05 motor
« Reply #2 on: July 06, 2013, 07:16:13 pm »
If not, the motor will spin both ways - if you wire either/or. And it wants to spin clockwise ideally. So bench test it, and the configuration that spins it clockwise will put it back as it was.
Offline markcarl
Re: dc05 motor
« Reply #3 on: July 06, 2013, 09:36:55 pm »
hi thanks for your input, yes thats the motor i have, 1 cable went to that wire thats circled furthest left and then the other 1 went on to like a spade thats attched to the motor, sorry for being so vague, its just just that i dont know which is the live or neutal and i think its got 2 fixing spades thats fixed on the motor and i dont know which 1 of these i attach it to....
i can take a pic and upload to see if that makes things easier
Offline markcarl
Re: dc05 motor
« Reply #4 on: July 06, 2013, 09:44:53 pm »
the 2 white wires on the left have both got terminals where i could connect wires to if i wanted but i know that will be wrong cos i know i disconnected 1 from the hanging thing on the right
Re: dc05 motor
« Reply #5 on: July 07, 2013, 05:33:18 pm »
Generally, the live will be the one with the most protection, so I would go live into the one on the wire and neutral to the spade on the motor.
I'll check with our chap tomorrow, but I am pretty confident about that.
Offline markcarl
Re: dc05 motor
« Reply #6 on: July 07, 2013, 09:10:06 pm »
ok thanks, can i put the neutral to either one of the spades as there are 2 on the motor
thanks
Re: dc05 motor
« Reply #7 on: July 08, 2013, 11:12:58 am »
thanks
If they are next to each other, yes. One will be an extra spur that is used on Motorhead models.
Re: dc05 motor
« Reply #8 on: July 08, 2013, 04:00:26 pm »
Yes that is right.
