Author Topic: Remove broken Pre-Filter Catch ~ DY-903346-05  (Read 14716 times)
Offline tmf
« on: January 17, 2014, 04:31:18 pm »
Our DC07 suffered a broken Pre-Filter Catch ~ DY-903346-05 where the base of the 'Catch' is still in the mounting hole.  I can't seem to figure out how to get the remainder out of the mounting hole.  Can't seem to pull it out (not a lot to grab onto to pull) and doesn't seem feasible to push it on through.  Can anyone offer some advice?
Todd
Re: Remove broken Pre-Filter Catch ~ DY-903346-05
« Reply #1 on: January 17, 2014, 09:22:09 pm »
To clarify for others, you have snapped off this clip:
A thin flat blade screwdriver, and push it out from behind is the way to remove that. A short sharp shock from the palm on the handle of the screwdriver.
Offline __russ__
« Reply #2 on: January 18, 2014, 08:35:51 am »
(Attachment Link)
There's that exhaust pipe that needs removing first to gain access to give it a whack from the underneath.
There's 5 screws that need undoing to release the motor housing and then the exhaust pipe should come free to get to that snapped catch.
Not as simple a job as one might imagine!
Offline tmf
« Reply #3 on: January 19, 2014, 06:58:29 pm »
Poking it out from the bottom was what did the trick.  The exhaust elbow did have to be removed as noted.  However, I got by by removing only the 2 screws from the elbow unit and also removing the 'lid' to the HEPA filter.  There was then enough play to remove the elbow alone.  Thanks for the help!
Offline spikey1509
« Reply #4 on: July 28, 2020, 01:24:34 pm »
You don’t need to move the exhaust pipe, once you have removed the screw, it will prise out, just done it on a DC07.😀
