Author Topic: Changing clutch belts, how difficult?  (Read 18937 times)
Offline Hoover Master
« on: March 15, 2017, 09:49:18 pm »
I am wanting to re-belt a few clutches seeing as it's so much cheaper than a replacement clutch. How hard is it? Any tips?
Re: Changing clutch belts, how difficult?
« Reply #1 on: March 15, 2017, 10:47:42 pm »
fiddly but doable. Plenty of how to videos on you tube and links on this site, if the white wheel is black then you need a new one, available from MV  :thumbsup: Tiny circlip is a pain and can fly off never to be seen again. A spacer to compress shaft is a god send, anything small and solid will work and a screwdriver with interchangeable bits, with no bits fitted makes fitting the aforementioned circlip easy, even better if its magnetic.
« Reply #2 on: March 16, 2017, 07:17:53 am »
Thanks  :thumbsup:
I have a spare clutch that's very stretched, I will try that one first.
« Reply #3 on: March 16, 2017, 08:23:05 am »
There is a topic on the subject with videos.
We also have the white wheels in stock in case of need.
« Reply #4 on: March 16, 2017, 05:30:15 pm »
I will look now  :tiphat:
Offline GeorgeJ
    • Some dirty pics ;)
« Reply #5 on: March 16, 2017, 08:07:08 pm »
I bought a replacement clutch for my DC14 a while back.  Recently, I changed the belts in the old clutch as well as the clutch in a DC33.  Not hard at all.  I would say the entire process took 10 minutes each while watching TV.
The biggest problem was getting the c clip off without damaging it (without the proper tool, that is.  I used a small flatblade and the clip paid the price.).  All I needed was a T10 torx, a larger (1cm dia) and smaller (0.5cm) flat blade, some grease and a cloth.  A knife is handy to speed up taking off the belts.  8)
 -Michael Scott  -GeorgeJ
« Reply #6 on: March 16, 2017, 09:27:39 pm »
Thank you all for the tips and experience. I'll give it a go when I find time  ;)
« Reply #7 on: March 16, 2017, 10:21:47 pm »
I never cut worn clutch belts, I think they make fantastic non clutched belts ;D
Offline GeorgeJ
« Reply #8 on: March 17, 2017, 02:11:27 am »
That's not a bad idea!  That must be the Japanese ingenuity I keep reading about.
(I know you're not Japanese, I just saw you getting razzed about that elsewhere on here ;D :underchair:)
« Reply #9 on: March 17, 2017, 11:54:16 am »
Lmao :))
 Thank you for understanding
Offline Vacsfoodreviews
  • Youtube Channel vacsfoodreviews
« Reply #10 on: March 17, 2017, 08:00:51 pm »
I tried replacing the clutch belts on my dc04 but lost the little circlip so decided to buy a used clutch instead then happened to find the circlip a few days later i used Quаltex belts which where cheap another problem is stretching the new belts over the motor shaft and brush it took me a good amount of time and swearing before i got them on but defiantly worth the time and money to recycle a old clutch i also greased the ball bearings when i had it apart which i dont know if that was the right thing to do but it seemed to make it turn smoother.
« Reply #11 on: March 17, 2017, 08:14:46 pm »
Big long flat blade screwdriver for motor shaft, belt tool for brush bar.
« Reply #12 on: March 17, 2017, 08:17:09 pm »
He is, he just eats too many microchips and he is now confused like a Computer.
« Reply #13 on: March 17, 2017, 08:25:35 pm »
Julie, calm yourself
« Reply #14 on: March 21, 2017, 06:05:59 pm »
Excellent tips, thank you  :tiphat:
Will try your belt idea tayyab
