Author Topic: DC07 Suction problem  (Read 10883 times)
Offline MalcyD
« on: March 25, 2017, 12:18:11 pm »
Hello all,
I'm looking at a friends DC07 (clutch version) which has great suction at the wand end but, little if any suction when in the reclined position. I thought I'd cracked it when I found that the brush roller bearings were siezed. I've replaced those with new but still no suction when reclined. There are no blockages anywhere and filters are clean. Has anyone any idea what the fix is?
TIA
Mal.
Offline mrdyson
Re: DC07 Suction problem
« Reply #1 on: March 25, 2017, 12:43:36 pm »
Have you removed the internal hose to check if there is suction there?
Offline MalcyD
« Reply #2 on: March 25, 2017, 02:16:24 pm »
Thanks for the reply. I thought you had solved it as when I checked the internal hose there were two large splits in it. I've fitted a new hose but still no suction. I'm wondering if the cyclone itself may be blocked?
Mal.
Offline mrdyson
« Reply #3 on: March 25, 2017, 02:36:23 pm »
If you have suction from the wand / hose there won't be anything wrong with the cyclone as you'd loose suction from both ends.
Remove one end of the internal hose, put the vacuum in the reclined position. Is there suction?
Offline MalcyD
« Reply #4 on: March 25, 2017, 04:25:26 pm »
Hi, just tried that and there is good suction. I suppose it must be the wrong internal hose that isn't fitting properly. Time to order a new one.
Offline mrdyson
« Reply #5 on: March 25, 2017, 04:31:30 pm »
First check that the brush is spinning freely and it's not slowing down when pressure is supplied. Next check that the soleplate is fitted correctly and is flush.
If these are all correct it must be down to the internal hose. When the vacuum is being reclined, check from the side of the machine that the rear of the soleplate is sitting flush with the floor. If a cheap internal hose is used or it isn't installed correctly it can apply to much pressure to the brush housing causing the rear of the soleplate to lift and loose suction.
Let us know how you get on.
Offline MalcyD
« Reply #6 on: March 25, 2017, 05:06:03 pm »
Thanks for that. I'm waiting the arrival of a new (hopefully better fitting) internal hose. I'll let you know if that solves the problem.
Offline mrdyson
« Reply #7 on: March 25, 2017, 05:09:33 pm »
Excellent, fingers crossed  :thumbsup:
Offline Elgin
« Reply #8 on: March 27, 2017, 09:58:13 pm »
Make sure the push end goes onto the main unity and the screw in end onto the brush housing
Offline MalcyD
« Reply #9 on: March 30, 2017, 11:10:08 am »
New internal hose arrived but, it will not fit onto the brush housing. I'm assuming this must be a 'compatible' hose which simply isn't the right size to 'screw' onto the brush housing. Anyone any ideas where is the best place to get a genuine (one that fits) internal hose?
Offline mrdyson
« Reply #10 on: March 30, 2017, 11:27:55 am »
Warm it up in a cup of warm water, it will be more pliable and easier to install.
But yes, I would recommend not using cheap internal hoses. They aren't worth the money.
Do MVacs sell them?
Offline MalcyD
« Reply #11 on: March 30, 2017, 11:55:12 am »
Thanks. I'll give that a try and report back.
« Reply #12 on: March 30, 2017, 01:00:54 pm »
We only sell genuine ones. We also sell DC07 workshop manuals;D
Offline Elgin
« Reply #13 on: March 30, 2017, 03:50:42 pm »
Make sure its not the clutched 04 one - they differ
Offline mrdyson
« Reply #14 on: March 30, 2017, 03:53:18 pm »
MalcyD has a DC07. The internal hoses don't differ for clutched and non-clutched machines.
