Author Topic: Miele S424i - Stripdown and Refurb  (Read 12586 times)
« on: April 25, 2017, 08:50:56 pm »
This used to be my mums
I got it for her soon after I met Amy, for £25 from Reading via ebay. It's been a good old thing, and served mum well. But, I obtained a free and quite battered Miele S5 for free from Facebook just after christmas, so I gave mum that (as it was too far gone to be refurbed, and made a good upgrade) and took this back to sell.
First up, the mini turbo brush I found to go with it
Pop the lid
Then prise the end caps off
This separates the two halves
The turbine and the framed end caps it sits in lift out and off the belt
Surprisingly this still span quite well
The axle doesn't come out of turbine (certainly not cleanly) so I cut and picked it all off
The baseplate and brushroll pop out of the main frame
Re: Miele S424i - Stripdown and Refurb
« Reply #1 on: April 25, 2017, 09:00:29 pm »
The white brushroll end caps prise out from the sides, then the brushroll can be removed
The brushroll got cleaned, and I started on the main turbo head
These screws turn (and are a bit chocolatey, so mind the screwdriver)
And the baseplate lifts off at the rear and unclips from the front
With that, undo the 4 normal screws and lift the top off
The suction valve unclips
Next, we need to undo these screws here holding this cover on
You can lift out the turbine and neck. The axle does push out of the turbine here, and needs to so you can seperate the two parts
« Reply #2 on: April 25, 2017, 09:10:22 pm »
The brushroll and belt guard lift off
The end caps come off the brushroll
And I cleaned the brushroll ready for washing
I left the wand alone, as it was fine
Hose now
The ends remove easily, no tools needed on the wand end
Some light tab flicking on the machine end
And we can finally move onto the actual machine 3 posts in!
and lift the first hood
« Reply #3 on: April 25, 2017, 09:14:19 pm »
Small tools off
The tool door is broken, I am hoping it will glue up at this stage in the past
So off it comes
Bag fill piston indicator now
2 screws has it out
and it pops apart
« Reply #4 on: April 25, 2017, 09:36:35 pm »
Next lid opened now, to reveal the bag door! (brand new bag fitted so I could sell the machine with a new bag...)
To remove it, push the 2 black hinges either side inwards one at a time, they pop off and the door lifts off
The bag door catch fell off in the car after some enthusiastic cornering when I forgot it was in the boot (I miss the Xantia, it did corner well!), so this is what it looks like if I had just taken it off...
Underneath the bag door, the hose inlet is fixed in with 4 screws
Once they are removed, it and the bag seal flap fall off
4 tabs split the unit down further still
The bag support is held in with a screw either side
And a spring which sits like so on the bag support and braces/springs against the main body of the machine
« Reply #5 on: April 25, 2017, 09:43:29 pm »
The post motor filter cage lifts out next
And these two screws need to be undone
Which enables the switch assembly to be removed
The part that rotates and turns the potentiometer when the power slider is adjusted lifts out
The power and cord rewind pedals pop out, each pivot is one big clip
The slider itself can be removed
Onto the electronics now. The black rod is a switch that is activated when the floor tool is parked in the cleaner, it turns the machine off (and has never worked)
It lifts out, along with the unplugged switch
« Reply #6 on: April 25, 2017, 09:54:59 pm »
The main on/off switch lifts out now, you can see that both are on the same circuit
it goes to here on this packed connector
Undoing some more screws enables the whole rear part to lift up, which will include EVERYTHING!
The cord rewind lifts out of the unit and the blue wire unplugs from the connector block, and the black from the switch.
Unplug the motor plug
The motor is held in by the one screw in a frame
And once unscrewed the motor can be removed
The fancase frame clips onto the top part of the vacuum
All the sound deadening can be removed
As can the connector block
« Reply #7 on: April 25, 2017, 10:00:15 pm »
Lots of sound deadening sits in the bottom of the machine too
Staying with the lower chassis, 2 screws hold the carry handle together
The furniture guard/motor housing seal lifts off then
Under these two screws is the power socket and wires
Once removed, the whole lot comes out
Underneath now
Pop each wheel off, and you can see the screws underneath
Undo all 8 screws and the wheel assemblies come off, and can be split further for lubrication
« Reply #8 on: April 25, 2017, 10:15:29 pm »
The last thing to come out is the side parking slot
and it's all done, and ready to be washed
and dried, polished and ready for reassembly
Wheels first
Put a smear of grease on the metal stub at this point
« Reply #9 on: April 25, 2017, 10:24:07 pm »
Side parking slot refitted
Power socket and wires fitted
And run around like so, with the plug fitted in place
The bumper/seal can be fitted now
Handle bottom fitted
Refit the sound deadening once it's fully dry to both halves of the casing
Pop the motor fancase holder in
This is the thermal cutout for the motor. Clean this up so it doesn't give false readings and overheat when it shouldn't!
« Reply #10 on: April 25, 2017, 10:27:33 pm »
Fit the motor and screw the clamp down
Refit the cord reel, not forgetting to pop the cables through the chassis to the top side
Wire everything up on the top side
Re-assemble the switch cover
And refit the speed control stuff underneath
And bolt it all down
Fit a nice air freshener
then fit a new post motor filter with cage
« Reply #11 on: April 25, 2017, 10:31:35 pm »
Screw the bag holder down
Pop a nice new pre motor filter in
fit a new bag
Fit the bag door latch
Reassemble and fit the hose entry parts, then fit the bag door. Line one side up, and fit the hinge parts, then lever the other hinge side on
Re-assemble the piston indicator
and screw it down
Then refit the tools and tool door
Sadly glue did not hold the hinge, but I was completely honest when listing it for sale and it still sold within 20 minutes, so it wasn't worth worrying about!
Main turbo head now
Pop the slider back into the hood
« Reply #12 on: April 25, 2017, 10:35:47 pm »
Refit the brushroll into the base chassis
Re-assemble the turbine and neck, and refit the cover
Then screw the turbo brush together and fit the baseplate
Re-assemble the mini turbo head
And the job is done!
It sold for £55 even with the bag door fault declared and shown the the buyer, who did not care, she had been wanting a 'nice Miele' for her dad for a while, and seemed impressed with this when I demonstrated it to her! So that's £25 to buy, then used for nearly 5 years, then sold for £55, so £30 profit for changing my mums hoover, bargain!
Offline GeorgeJ
    • Some dirty pics ;)
« Reply #13 on: April 26, 2017, 03:02:12 pm »
Congrats!  It's always great when things work out so nicely.
Also, thanks for the pictorial (as always!).
 -Michael Scott  -GeorgeJ
« Reply #14 on: April 26, 2017, 04:12:53 pm »
Yep, always good when I can make money by not doing much work!
