Author Topic: V6 head  (Read 3352 times)
Offline PANIC
V6 head
« on: October 17, 2018, 07:44:00 am »
Hi... got a v6 that was pulsing due to blocked filter --- now sorted, but the head is only running for 1 sec on each pull of the trigger....I assume head is the issue but can anyone confirm..... not had a v6 to work on before... cheers guys and gals
Re: V6 head
« Reply #1 on: October 17, 2018, 02:37:48 pm »
The head will want stripping down and cleaning out properly I'd suggest.
Offline PANIC
Re: V6 head
« Reply #2 on: October 17, 2018, 02:43:18 pm »
tested a little more...on 1st trigger pull both head and main motor run for a second or 2 and then both stop....without releasing the trigger main motor then runs fine...…
when tried without head fitted main motor runs fine on 1st trigger pull.....would I assume the head is drawing too much load possibly?
Offline PANIC
Re: V6 head
« Reply #3 on: October 17, 2018, 04:13:05 pm »
stripped head and disconnected belt.  runs fine.... brush roll drive is tight to turn....
