Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
With photos. Find it
>here<
Click
>here<
Home
Help
Login
Register
Panasonic MC-E42N - Stripdown & Refurb
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Panasonic MC-E42N - Stripdown & Refurb (Read 5053 times)
beko1987
Member
Country:
Gender:
Let's take it apart!
on:
November 28, 2020, 11:49:47 pm »
Tweet
Howdy.
I did this a year or so ago now, for another collector. With some tenuous distant link to his childhood, we have the Panasonic MC-E42N.
//www.youtube.com/watch?v=iJTH1JO3mns
Which was growing something
Electronic Speed Control
Brushing and Barring Brushroller
It was a decent little thing. But, it hides a dark secret, which we don't know about yet!
Cable unwound
The filthy vintage MK plug has no place here
Handle comes off with one screw
Then onto the bag door
Logged
beko1987
Member
Country:
Gender:
Re: Panasonic MC-E42N - Stripdown & Refurb
Reply #1 on:
November 28, 2020, 11:52:52 pm »
The post motor filter slots off
Revealing filth
Bag door latch unscrews
The TOP QUALITY paper bag gets slung far away
And we can remove these 3 screws
Which makes the hose fall off
The hose unscrews and strips down nicely from the ends
mmmmm
Onto the wiring now, and the 2 screws holding the front cover on can be removed
Logged
beko1987
Member
Country:
Gender:
Reply #2 on:
November 28, 2020, 11:55:47 pm »
The wiring cover came off really easily
But sadly bought something else with it
It's part of the body
The whole thing was covered in some sort of greasy crap, which was/had rotted the plastics!
Removing the speed control knob involves just squeezing these tabs
and discovering this...
Removed them anyway
And we can take a look in here
The bag piston indicator stuff lifts out, note the greasy crap
which was literally everywhere
Logged
beko1987
Member
Country:
Gender:
Reply #3 on:
November 28, 2020, 11:59:02 pm »
Whole thing didn't move at all!
Mains cable can be removed now
Then things lifted out of the way to get to the back of the switch
So we can push the switch out without the housing around it turning to powder...
Everything is sort of attached together when unplugged though...
So we need to move downhill, removing the rear wire cover as we go
And turn to the base plate
Which was flipping broken
Logged
beko1987
Member
Country:
Gender:
Reply #4 on:
November 29, 2020, 12:02:14 am »
I removed the glider bars
Then the air duct
And the pivot peg that holds the hood to the chassis. Sporting a pack-out bodge as these wear...
Recline lock pedal now, one screw on the end of the bar
And it lifts out
Next are these two screws which are the hood pivot on the other side
Then the hood comes off the back chassis
Let's take the motor cover off now and see what joy lurks within!
Logged
beko1987
Member
Country:
Gender:
Reply #5 on:
November 29, 2020, 12:05:13 am »
One surprisingly unperished post air diffuser
And the wires we need to seperate
Snip
Now the loom can be pulled up and out, removing all the electronics
This was loose, so I removed it, cleaned it up and re-pasted it!
More rock hard yet greasy bag housing seals
And more damage...
The pre-motor filter looks lethargic
But hiding under the fancy rear compartment cover are some tools!
Logged
beko1987
Member
Country:
Gender:
Reply #6 on:
November 29, 2020, 12:10:17 am »
The tool door cover falls off if you open it too vigorously so that was easy
Revealing the lovely Panasonic tools
These 2 brackets unscrew now
Rear wheels now, nice and simple
This looks normal...
This looks like a date code but I'm not clever enough to decipher it
Then we can de-rubber the motor
Logged
beko1987
Member
Country:
Gender:
Reply #7 on:
November 29, 2020, 12:13:36 am »
Back to the hood now
Belt doesn't look fab
On these brushrolls, you need a screwdriver
And splits down alot
Furniture guards off, these were the worst and got a whole sub_cleaning of their own!
With lots more broken plastic
All the grease was under here
Cracked
Not looking good...
Logged
beko1987
Member
Country:
Gender:
Reply #8 on:
November 29, 2020, 12:16:27 am »
So... Everything was washed. And, I discovered that the remaining pieces glued together quite well... So with a lot of qbond, I fixed it...
And got it all structural enough to be able to get here!
We can fit the now spotless furniture sliver
We can gather the pile of brushroll
Fit the belt guard into the hood
Throw the brushroll together, with nice fresh grease in the bearings
Logged
beko1987
Member
Country:
Gender:
Reply #9 on:
November 29, 2020, 12:19:28 am »
It can sit in here for now
The diffuser got hot glued back into place
And the motor was re-fitted, loom re-run and connected and sealed back up forever more
I wired the top end up as it stops the bits flopping about
Here is said new paste, the finest* stuff I had
Connect it all up
Then stuff it neatly back in
The bag door seal just about slid on to this! Wasn't quite as straight as it once was
But fitted onto the vac fine
Logged
beko1987
Member
Country:
Gender:
Reply #10 on:
November 29, 2020, 12:22:15 am »
Back down to the bottom, the hood can be re-fitted to the body
And the bung on the other side
Recline lock can be re-assembled and re-fitted
Brushroll connects up to motor now with a nice new belt
Air duct back in
Then the glued up baseplate goes on (after you've fitted the carpet gliders.... oops)
This all needs hiding
The tools and cover go back on
Logged
beko1987
Member
Country:
Gender:
Reply #11 on:
November 29, 2020, 12:25:04 am »
The hose wasn't fully dry at this stage so I screwed the body bit in as the hose fits easily enough with it on
Washed filter
A latch
And it's saved!
And when filming the after video
//www.youtube.com/watch?v=6n9bUAv7MxQ
Realised that their actually not bad, certainly alot better than the newer ones, which took all the grooming and contact with the floor away!
Logged
Print
Pages: [
1
Go Up
« previous
next »
