Author Topic: DC07 hose end  (Read 5043 times)
Offline cjrefrig
DC07 hose end
« on: September 20, 2011, 03:02:44 pm »
My hose split at very end attachment piece.I was able to take it apart and cut 10cm off the hose, now i would like to attach it back to the end ring.  Does anyone know the glue/epoxy that is used to attach the hose onto the attachment ring before it is slid into the end piece?
Offline Dyson Tech
Re: DC07 hose end
« Reply #1 on: September 21, 2011, 11:07:15 pm »
Use Evo Stick Pipe Weld.
It is designed for plastic waste pipe plumbing fittings, but it does a *great* job on Dyson hose ends.  :-X
Offline cjrefrig
Re: DC07 hose end
« Reply #2 on: September 23, 2011, 04:05:45 pm »
THANKS!! my wife is so happy. :))
