Hi all - just joined so this is my first post & would love to tap into the collective knowledge & wisdom of all you guys!
SWMBO (aka Da Management) reports that when using our venerable DC07 Allergy yesterday it worked OK for a few moments then “died” - the motor gradually slowing then stopping completely.
When I tested it there was nil response. I’ve checked the switch - power is on both sides - so not that. Checked blockages all round = none.
So, since these are essentially simple machines I’m thinking motor: but what’s the issue? Could it be brushes? How do you tell & are they easy to replace?
If not brushes, I’m assuming it’s time for a new motor… but can anyone suggest any other cause/remedy?
Any thoughts/suggestions gratefully received!
