Hi All,
I am in the process of having some of the most awkward and long obsolete parts reverse engineered and reproduced for the Electrolux Masterlux range of 3 in 1 cleaners.
Starting with the most common part which put the shampoo side out of action for many of them, the plastic "Y" fitting which connects the pump to the pressure switches and outlet on the front of the machine. The repeated pressure placed on the release button to remove the solution tube would fracture this fitting at the pump end.
As you can see below, the part is now at the prototype stage and I am expecting pre-production samples soon to make sure it is 100% right.
This is part no. 439532003 for the Z76, Z76A, Z77 Masterlux
I will be producing the later fitting for the Z78 Masterlux and Z85 Electrojet at some point.
Would there be any appetite here amongst collectors for these parts to revive their machines?
