Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
With photos. Find it
>here<
Click
>here<
Home
Help
Login
Register
The Clean World of... Eureka Forbes Euroclean 2000
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: The Clean World of... Eureka Forbes Euroclean 2000 (Read 1692 times)
beko1987
Member
Country:
Gender:
Let's take it apart!
on:
August 05, 2023, 09:10:07 pm »
Tweet
This was a fun cleaner to own, and a familiar one too! Welcome, to the magical world of Clean!
//www.youtube.com/watch?v=OqvMd5phHKY
I just cant quite place it's shape
Came with a cool bag
Let's start with the tools. The hose end unscrewed, and the rest are washed as they are
The other end of the hose comes off
The suction release valve comes off just like on the 1970's/80's Electrolux/Volta hose ends. It's uncanny...
Unlike the Lux ones the felt sealing pad under the slider is much plusher!
This wierd up high brush didnt come apart
Floorhead now, again a lovely clone of the Lux flip over head going back all the way to the 1950's
It's just made out of plastic, although with a nice metal base plate
Logged
beko1987
Member
Country:
Gender:
Re: The Clean World of... Eureka Forbes Euroclean 2000
Reply #1 on:
August 05, 2023, 09:14:38 pm »
This comes off with 2 screws
Then 2 plastic support braces sit underneath
Standard single pivot screw up front, but under a nice blanking cap
This releases the neck, and agai na much higher quality of fabric sealing ring
Onto the machine now, which yes is a clone for the Indian/that part of the world market of the Electrolux Z330 & Z345!
But without some features which will make refurbing it easier!
Bag open and immediately rather than a paper bag and oblong shape we see ye olde glory hole and cloth bag!
The bag was quite clean, this came from another collector so it wasnt utterly hanging, the dirt was from my use more!
However the plastic outer ring was showing signs of wear
Logged
beko1987
Member
Country:
Gender:
Reply #2 on:
August 05, 2023, 09:20:19 pm »
Deeper we go now, and back into familiarity
Almost. No rivets here, but nuts and bolts, with the aitflow being sealed by fibre washers! It was lovely and simple!
With the bag door off, we can just make out the ghosting for the mount where the Automatic plunger mechanism sat on the older machines. I wonder if Eureka Forbes got hold of the original moulds from Luton and just filed stuff down?
All we have is the latch and springs
2 more shorter bolts, no drilling needed here and the front wheel comes off
This was once someones home
I carefully popped those 2 lock washers off and the top plate lifted out
What happens now is the wheel and alll the ball bearings fall out! I spy signs of moisture ingress too...
Again though, nice little bit of detail, the bearings run between a bushing and metal race, rather than directly on the wheel assembly like on the original Electrolux design. I'm growing to like this
Logged
beko1987
Member
Country:
Gender:
Reply #3 on:
August 05, 2023, 09:27:52 pm »
Onwards! Post motor filter off, again all slightly re-designed but to within the overall existing dimensions
It's so premium
Back end now, and look up her holes and find the 2 screws either side
Pull the back carefully off, minding the switch wires at the top. The cord reel is safe for now
But not for long! I cut the OG plug off as it was cheap as heck and bendy and it's a 220v machine so I had to get an adapter for no reason at all.
Rescued the cable buffer thing though
We slide back into 345 normal-ness now and we'll have the cord reel apart
Basically, let the cable go, and let the spring fully un-tension. Then, undo the cross bar, and the now un-tensioned master reel un-hooks from the take-up/cord reel spool
The cord reel centering bar and a spring may come with it too as per the bottom right. That's fine, dont worry (yet)
Logged
beko1987
Member
Country:
Gender:
Reply #4 on:
August 05, 2023, 09:33:19 pm »
Things go very fancy now with a transluscent blue cord reel brake spring assembly holder, zero else on this machine has this plastic!
They must have had loads lying around at the time I guess
Time to get the flex off the reel
Undo the screw holding the red fibre cord clamp on
Unscrew the flex from the terminals and it's got a red outer shielding on it, which is not a bad idea as they can break the cable at this point on the Lux's
The rear wheels remove by popping out the inner white clamp, then they slide off and the bushings come off (all handed so it only goes back together one way, just like the originals!). Tyres are off the wheels too
Onto the MASSES of wiring this machine has now
Bullet connector on this black wire, just like an old Landrover!
The switch comes off next, again a familiar shape
Logged
beko1987
Member
Country:
Gender:
Reply #5 on:
August 05, 2023, 09:38:24 pm »
Different maker to any examples of a genuine lux switch I had though
And unlike the Electrolux sourced switches it fell apart which they dont often do
It was a bit iffy in use anyway
And obviously arcing alot so we'll treat it to a new one later
The motor holder/rear firewall comes out now, and again it's made of a much stronger palstic than the original clear ones Lux had! Far less brittle
Remove the wires at the rear (Red - Live Black - Neutral iirc)
Then the cord reel contacts pop out with some bending of tabs
Next out is another IDENTICAL part, but made from a much nicer material than the original
And finally the motor
Logged
beko1987
Member
Country:
Gender:
Reply #6 on:
August 05, 2023, 09:44:59 pm »
This sticker was under here, FAL Industries!
Bing's GPT seems to corrolate it
There's more stickerey joy on the motor. No idea what that means though
But again, it's a fully re-designed motor, but keeping the exact physical dimensions of the OG motors!
So similar I fetched an actual LUX motor for comparison (on the left)
Play time over, some past bodgery was uncovered.
Motor out, we'll get the rest of the trim off. Again, screws and not rivets!
The front filler piece comes out when the main frame is lifted just like the original design
And no hateful Automatic switch rod to contend with either 🥳🥳
Logged
beko1987
Member
Country:
Gender:
Reply #7 on:
August 05, 2023, 09:49:22 pm »
The front filler bit to make the hole round came off now it wasnt being clamped in too
The same big foam air diffuser was behind the fan case just like the OG ones
The bottom skid plate/Hanging Hook unscrewed
And we can get onto the motor!
Snipped the supressor off and had the brushes out
Under the brushes were the 2 long bolts holding the motor together
Out comes the coil
Then magically, unlike the original motor, there is a reason to tap the fancase off
Because a nut and thread rather than riveting it together was used in the motors redesign! So the fans could be washed which is good as they needed it!
Logged
beko1987
Member
Country:
Gender:
Reply #8 on:
August 05, 2023, 09:53:03 pm »
What was the same as the original design though was the micro cracking starting by the rivet/bolt holes... Not as bad though but qbonded straight away
The pedals are held into the frame with a metal spring
The motor bearings were filthy
As were the fans
But some brake cleaner later had them spinning as good as new!
Everything else was washed, polished and laid out for the usual!
I then sloshed some bearing grease into the bearings
Built the fancase back up
Dropped the coil and top bearing cage on, motor spinning smooth as silk at every stage
Logged
beko1987
Member
Country:
Gender:
Reply #9 on:
August 05, 2023, 09:59:04 pm »
The carbons went back together and for now the motor is done!
Because trim needs to go back on first! Front metal adapter slid on
Then the top frame and FIT THE PEDALS NOW as you have to! I had to strip alot back down whe nI realised I remember writing this now....
But we can laugh at my stupidity as we put the foam ring back onto the motor, whose wires have been extended
In it goes!
Wiring up! We have the live from the cord reel going out towards the switch, then the wire from the switch coming back to the motor. Neutral to the cord reel, then a 2nd neutral going off for the LED light.
We can pop open our brand new switch!
And wire it in, wiring the LED Live off one side
I put all the wheels back together
Logged
beko1987
Member
Country:
Gender:
Reply #10 on:
August 05, 2023, 10:07:24 pm »
Back to being the same as the original design, the cord reel brake arm goes in, with its brake pads set as so with the spring sat in the notches. It all stays pretty together but has to look like this!
I then wired a nicer white flex onto the reel as the one on it was horribly hard and thin, this one is much more rubbery and off an Electrolux of some sort IIRC. Then the reel drops onto the centre post, then (and this is tricky), with light pressure on the reel, push teh release rod as if you were the pedal so the brake pads close in, and slip into their bit of the cord reel. Then, DO NOT MOVE IT or itll pop out again!
I didnt take good photos of this stage (but have a 330 and 345 thread to do so we can cover it there) but take the small spool of cord rewind spring, drop it onto its post and slot the connector back into the cord reel. Leave the plug off, and screw the diagonal support bar down. Using thin pliers to help the end of the cable around the housing, make 3/4 turns of the cord reel to start tensioning it. After 4/5 full rotations, push the end of the cord throuhh the hole in the wheel and make sure it cant pull itself back through whilst you pop a plug on it!
Once you've done a few it makes more sense
At this point theres a large time gap between that picture and this one, so I must have noticed I'd not put the pedals in. Luckily all I had to do was pop the motor firewall back off, undo the 4 bolts and quickly re-assemble it until we have this!
Screw the back onto the main housing and check for proper operation of the cord reel
Onto the front wheel now! Little foam ring refitted
I then covered my balls in grease to make them stick to things
Logged
beko1987
Member
Country:
Gender:
Reply #11 on:
August 05, 2023, 10:11:18 pm »
This made them stick together whilst i pushed it into the main housing, then put the backing plate on and pushed the 2 grip clips to hold it together! Buttery smooth* now
Refitted to the machine
The bag door took ages to re-assemble
But fitted a treat! All bolts nipped up now
Then for bodge 2! Some tape to make a lump in the bag inlet port
Which enables a cheapo nasty pattern Miele bag with a small opening to slide on and grip nice and tightly!
Yes, it will Hepaflo!
Won't be much use for anything without tools though. The red felt was even plusher now it's been washed! Took alot of slop out of this joint it did
Back in
Plastic spacers in
Logged
beko1987
Member
Country:
Gender:
Reply #12 on:
August 05, 2023, 10:16:21 pm »
Then the base plate. I assume it would have had a dedicated hard floor brush, but I did not have this. 32mm tools though so no biggie!
The hose bleed valve sealed up MUCH better now its pad had pile
Hose end reassembled
All tools reassembled
And she's back together!
The suction was pretty decent, decent enough that I could use an Airo brush on it with no bother
It came up very well indeed!
//www.youtube.com/watch?v=b1kshUarnFg
And an interesting project is written up! It's nice too as going into it I thought this would be an awful clone, cheap and nasty but actually, it has more nicer touches and better bits about it than the original designs! I sort of wish I'd kept it, and maybe put some nice older style Electrolux tools with it and had the best of both worlds, but she's been sold a while now!
Thanks for reading
Logged
CountVacula
Member
Country:
Reply #13 on:
August 31, 2023, 02:46:44 am »
Beko, are the main bodies on these steel like the original Electrolux product or plastic?
Thanks.
Logged
Print
Pages: [
1
Go Up
« previous
next »
