Author Topic: SV14 (V11) NOT the usual pulsing.  (Read 717 times)
Offline NikGrey
  • If I can't fix it, you'll need a New One :)
    • Links Repair Shop
« on: October 04, 2023, 07:11:48 pm »
I have Been repairing Dyson as well as most other Vacuum Cleaners (Excluding Shark) for 8 years now, I'm in Hellesdon - Norwich. (Links Repair Shop) and I have come across a problem I have never seen before with an SV14.
This is the only place to turn in situations like this and I am thankful you are here.
I have not gotten right into the actual motor yet, I think thats the next step as I feel that this problem may be caused by a sensor that I am yet to discover - there is very little info on the web about these machines at the moment.
The machine pulses very quickly on low, less quickly on Med and I get a good half second blast on Boost.
The machine is now completely clean internally as I gave it a service, I bypass the filter Hall effect switches with a magnet rig I have made.. and in any case new filters make no difference.
Has anybody come across this issue and fixed it?
Any further idea's ??
TIA.
Nik Grey.
I own and Run Links Repair Shop in Norwich. I coined the phrase 'The Dyson Doctor" in 1995 but at the time I was not able to buy the domain, I lived on Corfu where there was no internet and by the time I came back to the UK that name was used everywhere !
Re: SV14 (V11) NOT the usual pulsing.
« Reply #1 on: October 06, 2023, 12:48:39 pm »
We are starting to see this quite often now.
It is definitely a fault in the motor body as you note, we have a tea chest full of bodies that do this.
We just fit a replacement motor body.
If you do happen to identify the component within that fails, I'd be interested to know too.
Offline matrixresonator
« Reply #2 on: October 11, 2023, 09:12:51 am »
Seem to remember reading something somewhere about a dirt sensor that fails in the body which incorrectly identifies a blockage, but like you say it's a new body.
