Author Topic: Compatible parts for a DC46 wand (with power) replacement?  (Read 197 times)
Offline bobertbeen
Good day.
Does anyone know if it is possible to get a replacement or compatible wand (or wand with hose) for a Dyson DC46 (I think it is the DC47 for you in the UK?).  I am having a similar issue as another member whereas the powerhead cut intermittently when the hose swiveled in a certain direction (ours only worked when twisted to the right).
Any direction on a possible replacement or if it can be fixed would be greatly appreciated. I know it is an older vacuum but it has been great and the size and weight is perfect for our home.
Thank you in advance for any advice.
Re: Compatible parts for a DC46 wand (with power) replacement?
« Reply #1 on: May 01, 2024, 01:04:59 pm »
There is a strip down topic >>here<< on one of those.
If you have an electric hose variant, it will be a broken internal loom near the moving part you mention. They are fiddly to fix though. A used replacement from somewhere like eBay might be the best bet unless you are especially practical.
Offline bobertbeen
« Reply #2 on: May 01, 2024, 01:22:24 pm »
Thank you very much for the advice.
I will try the tear down and hopefully not make it worse :)
