Author Topic: DC24- Testing pcb and motor??  (Read 10463 times)
Offline tickz
« on: May 27, 2013, 03:24:30 pm »
Hi All
I have searched but cant find a definitive answer! so im just gonna ask before I order a new motor..How to I correctly check the motor and pcb for fault??
the brushbar doesnt work, I have stripped down using the walkthough sticky (thanks  :thumbsup:) and I want to test the motor and pcb and see whats at fault. (i have triple checked the red reset switch)
im getting 334VDC from the motor output on the pcb- does this sound correct??
what resistance should I have over the motor?? I seem to have an open circuit?
thanks in advance
 :thumbsup:
Re: DC24- Testing pcb and motor??
« Reply #1 on: May 27, 2013, 06:05:47 pm »
334vDC sounds high. 234 might be more normal. This is a UK machine?
I'd be looking for 400Ω across the motor and 725Ω across an assembled cleaner head terminals on a 220-240v machine.
Offline tickz
« Reply #2 on: May 29, 2013, 09:57:20 pm »
Hi thanks
yep double checked its 333vdc from motor output on pcb? this is a uk machine.
and the motor is open circuit (infinite)??
its got 333vdc with the motor disconnected. could be both??
thanks
« Reply #3 on: May 31, 2013, 01:12:57 am »
We have occasionally found the PCB can take out the motor.
Sounds to me like both.
Offline spikey1509
« Reply #4 on: June 06, 2013, 09:43:17 am »
Hi All,
   Is it possible for the motor to take out the PCB board as well or is it more likely to be the motor?.
Jason
Offline Dyson Tech
« Reply #5 on: June 06, 2013, 02:18:41 pm »
We change (and sell) probably ten or twenty times more motors than PCB's if that helps.
Offline spikey1509
« Reply #6 on: June 07, 2013, 11:53:12 am »
 ;)Thanx for that, I've ordered a DC24 brush bar motor, so hopefully that will do the trick, otherwise it'll be the board. I'll let you know how I get on.
Kind Regards,
 :tiphat:Jason :tiphat:
