Author Topic: DC18 brush bar.. help !!  (Read 5230 times)
Offline brett83
« on: August 04, 2014, 02:38:29 pm »
Hi All,
I have a DC18 to repair.  On inspection it was evident that the wiring loom had gone open circuit so i ordered one of these.
Ive fitted it and the brush still wasn't going around.
I removed the motor and hooked it up to a DC power supply as the voltage went up it began turning, so the motor must be fine.
I have buzzed out the power switch and brush switch and there is continuity to the 2 pins where the brush head connect.
I suspect it could only be the PCB or brush reset switch ?  but i cannot see any obvious defect on the PCB and there is also continuity between the reset switch.
Any ideas ?
Offline brett83
Re: DC18 brush bar.. help !!
« Reply #1 on: August 04, 2014, 02:42:25 pm »
Also, if there is continuity between the top power switches and the brush head connector on the bottom then surely the micro switch is OK too.  I think I tested this first anyway
« Reply #2 on: August 05, 2014, 01:11:50 pm »
To isolate the PCB as the fault, you will need to rig it up and check the juice is reaching it but nothing is coming out of it.
But if the motor works, and the head is getting power, the PCB is the likely culprit. Damage isn't always visible.
Offline brett83
« Reply #3 on: August 05, 2014, 05:43:24 pm »
Thank you do you have a spare?
« Reply #4 on: August 05, 2014, 08:52:27 pm »
We have new ones, but we might also have some alright used ones. We are closed till Thursday now, Ill take a look then and shoot you a PM.
